Freebee
I am rewiring the boat. Its 12v and I need to connect up, bilge pumps, level gauges, VHF etc etc. what size and spec of cable should I be using???
good answer but I was hoping to buy a 20 or 50 m reel of a one size fits all cable to use for all the devices, is that not possible?
Choose your circuit voltage (12v or 24v etc), full in expected length of cable from battery or source of power and fill in the appliance amperage as read from the sticker/label. Press calculate to see the cable size recommended.
No link.No need to go around installing unnecessary massive large, heavy and unsightly cables if the apppliance can do with smaller ones. See cable size calculator linked above.
Link fixed in the post above.
I think you will come a long way with one reel of 2x1,5mm2 (don't use anything thinner) and another reel of 2x2,5mm2 for more power hungry or voltage drop sensitive loads. Might not cover everything, but a lot.
Using it would require at least 6mm2 cable for a 25W masthead light. I think most of us with small boats would use 2.5mm2 as the larger cable would not fit the terminals.
