whiteoaks7
The question's in the title; 100C? more? less?
water temperature in an indirect cooled engine is usually much higher than a direct cooled engine
+1In Car engines, the water is at 85 to 90 degs C, dependant on the exact type of Thermostat, however the Oil temp runs a little higher, at anywhere between 100 to 120 degs C.
On a Boat diesel engine, although I dont know the exact figure, I'd expect the oil temp to be a little lower, say between 90 to 110 Degs. This would be due to the constant (and comparitivly low) RPM's that boat engines tend to run at for fairly long periods of time.
Regards.
