I d-don’t know.What is an M Motor ?
What does it get its signal from? A master compass?I'd say that it was a repeater, such as seen on a bridge wing.
Thanks - I had to google pelorus but I think you’re right. It has an MOD sticker on the bottom. I wonder where it has been? And what on earth do I do with it? It hasn’t passed the Mrs Shuggy test…I think it's a pelorus display in some sort of non-operational frame, minus much of the 'doings' underneath.
Both inner and outer scales are mirrored showing they are intended to be read both directly and via a rotating prismatic viewer which is missing. The inner card is a simple compass display (likely a gyro synchro repeater) that rotates in the usual way while the very outer ring (ivory colour) is fixed relative to the ship's head to simultaneously give both the magnetic bearing to an object as well as its relative bearing to the ship's head. Its function is a more complex version of a hand-bearing compass with a relative bearing feature added.
Quite what the ABCDEF means doubtless someone more familiar with such things will explain in due course.
It is a motor used in instruments (repeater) Years since I worked with them so hazy on detail. That looks, as already stated, Like a repeater, for a (Very) old Admiralty magnetic compass system. (WWII) vintage originally.What is an M Motor ?
I suspect it is an electric repeater where a signal from the main gyro compass drives a stepper motor in the repeater in possibly 1/2. degree Stepps. That is possibly a 3 or 4 pin connecter . There would be one on each bridge wing as well as a steering compass at the helm. Some times the steering compass was digital and above the forward bridge windows .What does it get its signal from? A master compass?
Perhaps for reporting aircraft?Still no idea about the ABCDEF though
Not what I said.It’s in a polished wood bezel......so....probably not an aircraft instrument
I know that...but I was leading up to it might be from a dashboard of a JagNot what I said.
If we accept the opinions up thread that it's from a large ship, used to report contacts, then reports of aircraft contacts might also be required.
Mr angry.Not what I said.
