Portofino
Well, forget the "spare" if you wish, but that's how his "syphon some power" concept came across - to me, anyway.
Regardless, if that's all you have to criticize in my train of thought, I can live with it. :encouragement:
Btw, what you are now saying is not how the throttles work on diesel engines (within limits, obviously).
When the captain press the magic button without touching the throttles, rpm/speed do not drop one bit, in theory.
You should only see the difference in the MTU (in this specific case) displays, which would show a higher load and instantaneous fuel burn.
Yes I’ve toyed with that .Not sure let’s discuss -
Thinking smacking into a biggish wave on the nose —- watch the speed drop off a bit - load stays the same ,so does the fuel burn , then speed recovers until the next time .
So,s the loads just set via the throttles say 80% but the speed varies depending on the wave resistance.
So ,s extrapolate that —- set the load in this case @ 14 knots on this boat .Press the magic button .
The resistance is now the shaft geny not the wave .
I would expect the load to stay the same ,but the extra energy taken out to drive the shaft geny s ( prob low friction brushless jobbies ) to slow the boat a bit . For the same load / fuel burn .
If they want to keep going @ 14 knots - then after a few mins when the speed drop has occurred, ease up the sticks and the load / fuel burn follows .
Or , when batting along watching the load / fuel burn , if you drop the flaps deep .
The only thing that changes ( sticks nit touched ) is the speed drops .
What I’ve done here is deliberately increase the drag —- but the engine s don’t know that and carry on as before .
Was thinking the engines don,t know if the magic button is pressed or not .
