srm
As for being able to sail a classic in close quarters, it's not easy. Especially earlier designs with a full forefoot. Sailing almost any classic into a marina is almost an impossibility unless your berth is right on the outskirts.
I fully accept the problems of sailing any boat within the confines of a marina as I have found handling a modern 43 ft yacht under power with lots of windage a bit of a challenge at times despite the bowthruster (which I usually forget to use as its not my boat). My permanent marina berth is chosen so that if sailing in or out I have the option of warping on to a hammerhead if need be. I do practice sailing when conditions are suitable as the only way to really learn how your boat handles is in close proximity to fixed objects. Also, I enjoy it.
However, I would point out that most 'earlier designs with full forefoot' were designed before internal engines were common or reliable. If they had an engine at all it would have been a few horse power to provide propulsion in a flat calm and was definately an auxillary. They are clearly not suitable for marinas, even under power, but I would define sailing on and off a swinging mooring or anchor as close quarters handling, and the early owners of your classics would have regarded this as the norm. It may not be easy compared to modern dinghy type hull and rig yachts, but surely that's part of owning such a boat.
If in doubt about the possibility of handling a boat with a long fore foot under sail in close quarters look a the late 19th/early 20th century photos of the sailing herring drifters, how do you think those guys got in and out of harbour? (many of which are packed more tightly than a Solent marina at high season). The dipping lug rig was the norm on the east coast, but the Shetlanders always used a gaff rig on the main as they often had to beat significant distances in the narrow voes of the islands, but either way these boats were primarily worked under sail with a long sweep as back up.
