What grease for Dinghy Trolley Wheels?
Mark-1
22 Sep 2008
Plastic (Nylon?) Wheels on ferrous metal axles.
I currently use silicon spray. Is there anything better?
TIA.
Blake’s seacock grease is pretty sticky stuff. Blurb from website here:
“A specially formulated waterproof grease from Blakes for seacocks, a very high quality synthetic grease for water and marine environment Formulated for marine use. High adhesion properties, working temperature range -30C to 70C”
I also have always used standard marine grease, what I use for the prop-shaft
I googled my marine grease (Carlube) and apparently it's calcium grease which won't effect the wheels. (Calcium isn't written on the tin. 😡) So I'm using that.
I would just use that tin of old stuff in the back of the garage. Regardless as to what it is exactly.
Yes, there was an unwritten requirement that it had to be in my garage already, but I have a wide selection. As it happens Calcium Grease is fine and I had some.
