What dinghy has the biggest tubes?
prv
29 Nov 2009
Southampton
My quest continues for a dinghy that can get three large people (well, two large and one average-sized) ashore with dry bums, yet fit into a small locker. In the last thread, the realisation dawned that the key factor is not the length or size of the overall dinghy, but the diameter of the tubes. In small inflatables the only place to sit is on the sides, so more diameter hoists yer bum further above the waves. The ideal would be almost all tube, with just a small well in the middle for feet.
Who makes a dinghy closest to this?
CAPTAIN FANTASTIC
15 Jul 2009
Bristol Channel
Generally, inflatables of 2.9 m length and above have large diameter tubes, but naturally are heavier; the inflatable which are advertised as lightweight have smaller tubes; I have a waveline 2.9 with v hull and large tube; has been good for the last 8 years and will carry 4 people easily.
pvb
UK East Coast
Zodiacs have fairly chunky tubes. The Cadet 260 Aero has 45cm diameter tubes. They're well-made inflatables too - I just bought a 240 Aero this morning.
Sailingsaves
26 Feb 2013
Is it possibly for you to make thwarts that go across your current dinghy so people do not need to sit on tubes?
Bit like the yellow avon thwarts that slot into place on tubes.
Or would thwarts be too bulky for locker?
Mistroma
22 Feb 2009
Greece briefly then Scotland for rest of summer
www.mistroma.com
We bought a small Lodestar about 10 years ago on basis of quality and size of the tubes plus airdeck floor. Our previous dinghies had always been too big and too heavy. It still looks pretty new and is used a lot as we love on the boat for about 6-7 months each year.
I think that tube size is the same throughout their entire range. The 195 model is closest to your description as it is tiny but has huge tubes (but only designed for 2 people).
195 was just too small and we found the 220 suits us perfectly. Normally 2 people with heavy shopping (or 2x25litres diesel cans), so total load about 150kgs. 3 people a few times and 4 just once (very crowded).
I believe that they now do a 230 model and that's the smallest worthwhile version for 3 (friendly) people. Worth looking at Lodestar but no idea which model would suit you best (amount of use, how rough water in area etc.).
D
Deleted member 36384
Well, to be honest, my friends on the way back from the pub would be hard to beat.
charles_reed
29 Jun 2001
If you choose a dinghy with an inflatable keel, it will tend to ride higher and drier than one with similar size tubes with just an inflatable floor. I have reservations about you being able to find a large-tube inflatable which can be folded small.
When I was looking for a replacement for my current dinghy (which has 45cm tubes) the best I could find was the Excel SD235 at a budget price and reasonable length.
pvb
UK East Coast
I've just been through the buying exercise, and have compared most reasonably-priced small inflatable tenders. As I suggested earlier, the Zodiac Cadet 260 Aero would be about the best compromise of size and tube diameter. It has 45cm diameter tubes and packs down to 100x55x30 cm - just 5cm longer than your Excel when packed
jerrytug
N/A
31 May 2006
Lorient
Yamaha 2.2m, 2.2 metres long. Gigantic tubes, big weight carrying capacity for 2.2 m LOA. Also has quality build, made in France not China. I am very pleased with this boat. Planes very well with one person and a couple of jerrycans on Tohatsu 3.5. Also carries big loads at displacement speeds.
The trouble with big tubes is, they contain more fabric, whick takes up locker space.
prv
29 Nov 2009
Southampton
Hah. Look, I weigh just over 120kg. My mate is if anything bigger. The third regular member of crew is rather less, but she's still a healthy outdoorsy sort of person, not an anorexia case.
(Thanks to everyone for the suggestions though.)
jerrytug
N/A
31 May 2006
Lorient
Err.. well they're 36cm diameter, hardly gigantic.
Whatever, but when you actually look at, or use, the boat, they are gigantic for a 2.2m, and it also has a very wide beam, FOR A 2.2 METRE LONG BOAT. You can verify this since you have the information at your fingertips.
The OP was asking for short inflatables with fat tubes, and my Yam 2.2 is a prime example. Is your period due by any chance?
