andrewAB
Hi,
Trying to decide on what if any external battery fuse to use on a new battery.
I'm looking to replace my 7 years old pair of Trojan T-105s (220AH @12V originally) with a EEL DIY kit 12.8V and 280Ah CATL cells.
The EEL kit comes with an internal 250 Amp CNL fuse and 2.5K Amp interrupt rating.
MRBF terminal fuse have 10K Amp interrupt rating.
The best to use would be Class T with 20K Amp interrupt rating.
Reading the specs I've found online BlueSeas 250A Class-T fuse would blow at 1000A in 0.1 seconds at a current below its interrupt current rating , whereas a Littlefuse 250A CNL would take 2500A in 0.1 seconds and could theoretically arc if the battery terminals were short circuited.
The Blueseas MRBF would blow with 1375A in 0.1s and well under it's interrupt current rating. This seems safe enough to me and easy to install. Any issues with using this?
If it is a decided a Clsss T is required how would I connect the Class-T fuse holder to the battery? A 70mm2 (485A) 30cm cable with M10 lugs is what I use to my Smartshunt on the ground, so similar on the 12V main?
BTW following are link to the EEL battery kit and cells they can provide in Europe and a summary of the blow time vs current I found from online specs.
Andrew
https://www.eelbattery.com/12v-life...e-bms-set-eu-warehouse-shipping-p5733618.html
https://www.eelbattery.com/copy-of-...or-solar-energy-diy-eu-shipping-p5842165.html
Blueseas Class-T trip delay
20K Amp interrupt rating, 125V, extremely fast acting. Would blow with 1000A in 0.1 seconds.
Littlefuse CNL 250
2.5K Amp interrupt rating, 32V, fast acting. Would blow with 2500A in 0.1 seconds -> at interrupt rating current
Blue Seas MRBF 250A 10K Amp interrupt rating. Would blow with 1375A in 0.1 seconds
Time Class-T CNL MRBF
0.01 5X rated 25X
0.1 4X 10X 5.5X
1 3X 3.2X 3X
10 2.5X 1.8X 2X
100 2X 1.4X 1.5X
500 1.5X
Andrew
Littlefuse CNL 250
0.01 5X rated 25X
0.1 4X 10X 5.5X
1 3X 3.2X 3X
10 2.5X 1.8X 2X
100 2X 1.4X 1.5X
500 1.5X
