Divemaster1
Ps. If you cut the fuel off to that injector how will it lubricate cylinder?
Won't cut off fully really, just scaled back by about 90% ... also, piston crown (compression rings onwards) is stuck at top of cylinder and does not move... Piston skirt and oil scraper rings move..., so will have oil lubrication...
Only intend using the engine for manouvering until re-build, so will be low use irrespective..... and obviously, the cylinder liner and piston needs replacing anyway... Piston pin etc., are OK and firmly in place..
