herdman
I currently have a Westerly Griffin bilge keel that I keep on a swinging mooring in Poole harbour. I draw about 3'1". I am told that at my mooring I will not dry out even at spring lows with a draft up to 3'6" - So no problem. However I need a larger boat and in particular have my eye on a westerly oceanquest - again with bilge keels but this time drawing 3' 11". The boat yard say its fine to have a draft up to 4' on my mooring (and weight is no problem) but it just means that I will dry out during spring lows. I do not mind this but someone told me that its very bad to keep a boat like this for long periods on a mooring as during heavy weather at low tides the boat will "bounce" on its mooring with the rudder crashing down on the ground as the bow rises on a wave... should this be a concern? Do I need a new deeper moornig? And if anyone has any thoughts generally on this model (or any of the others that came after the seahawk) I would be very grateful. In particular is the aft cockpit version preferable?
thank v much in advance,
Giles Herdman.
Giles Herdman.
