nevertheless
New Member
I just obtained a westerly centaur cheaply, that included some problems. Hopefully you can advise me how to approach the issues. I have not found exact what-to-do's yet, but I understand these topics are not unique for Centaurs. The boat is an early one, the previous owner says from 1976. Number 231. As such, it has the stays fitted above the front cabin windows. In both port and starboard windows under the stay, the metal edge shows rust and the windows leak. I can imagine that the stay deforms the hull around the window, creating a leak.
The boat is not out of the water standing on its bilge keels. It has been out of the water for about a year. Keels have been cleaned/sanded/painted by the previous owner. I now see lines of rusty moisture coming from the joint between keels and hull. I see this on both keels on both sides of each keel. About 2 - 4 lines of rust running down.
there is a bit of water in the bilge, but not so much. Keel bolts look clean from above.
I am afraid for having to loosen the keels from the boat: that might be a lengthy job (and a bit dangerous), building supports for the keels and supporting the boat itself. What would you advise here? Is the rust a sign of rusting keelbolts? Or of a rusting keel around the bolts? Or is there always expected to drip some rust from the top of the keel, as that connection to the hull moves a bit and can I guess maybe never get really painted well.
I would love to hear your advice. The more details, the better!. And my apologies for my english, I am actually dutch.
