Well that was an interesting sail
Thanks for the write up, food for thought. We generally try to avoid sailing near the French islands in darkness for this reason.
Did you heave to, or was the boat hanging by the stern too much to allow that?
We couldn't heave too due to the tangled Duogen. We needed to take the pressure off it so dropped all sail. That worked but the pot lines then tangled with the prop. We don't normally catch lines. With a deep fin keel that slopes up the leading edge, we tend to just go over them. The skeg hung rudder is 750mm higher than the bottom of the keel so as long as we are sailing fast enough, the lines don't catch the rudder or prop. The folding prop helps I think but not when you are drifting sideways over the line
