weigh in damaged props or refurb and sell?
DougOut
7 Feb 2020
Wiltshire
The props from my Broom 345 were replaced by the insurance company after I hit something very solid on the river. I kept the old ones but over the Christmas break started clearing the garage out when I found them with my ankle!
What's the opinion on disposing of them
  1. Weigh them in for scrap
  2. Get them refurbished and put them up for sale
  3. put them up for sale as is
Happy new year to you all
Regards
Doug
Depends on the condition of the metal.
If pink, has cavities and is crumbly, then scrap.
Else refurb and sell or sell as is.
All imho.
All imho.
Material is in good condition. Do you think there's a market for second hand props? Would they only be of interest to people if they had the correct pitch and shaft diameter?
My brother has just had a stainless steel 22" prop repaired by Steel Developments.
It was pretty mangled with a tear in one blade.
Repaired, sprayed black and returned for £150.
Check their website for pricing.
Probably worth doing as I imagine a new prop for your Broom would be a few quid....
Well you could try selling - if nothing happens, you have a known good set of spares.
Regards
Doug
Repair and keep. If you have damaged them, the same is likely to happen with the new ones. Having spares and even keeping one on board means you carry on boating.
Get them repaired - if possible and keep them. If you boat on a river sooner or later you will probably clatter your new props.
All too easy on some of the shallow canals around here, did it with a 6.5m sloop we had hired, lucky the rudder touched before the prop and was able to back off the throttle a bit and re-position the passengers, canal was just 1m deep.
I keep a spare pair in the stowage at the bow, helps with weight distribution on my Ocean 37
A serial prop bender of some repute...and was always on the look out for spare pair of props !
Depends on the boat, the size , the pitch and the shaft diameter.
At the budget "Broom" end of the market the cost of repair might exceed what somebody running a boat on a "shoestring" is prepared to pay.
At the other end a set of repaired 5 bladed props off a Broom 450 might represent a sensible saving of money over new.
Would pop them on as is on ebay.
I've seen adverts for spare S/H ones for the Ocean 37 being offered from £250 to £750 for the pair
New 2K ? a pair plus the down time getting them set up with correct taper and pitch etc.
Possible that some of the established prop shops are buying a stock prop before finishing them off to the customer requirements.
Michegan Wheel (UK) used to offer some very competitive prices, recently sold and now known as ..
Home - Nakashima Marine Propulsion International
Inboard Propellers Archives - Nakashima Marine Propulsion International
The prop on my AQ270 has caught when exiting my home channel .... I looked online at new prop ...
I will take hammer and wood block - carefully redo the blades ..... luckily its deformed outer edge of blades.
To OP ... I would sell as is - there is likely someone out there with the skill to repair ... willing to pay sensible money for them.
I sold an old bronze prop of my Mitchell 31, that was beyond salvage for boat use, to a guy who wanted it for a garden ornament - about 15 years ago now but got around £50 for it
