matt1
Hi Everyone
My aftmost keelboat has a very slow weeping leak after 8 seasons use. There is rust on the hull/keel joint visible around where this stud would be and inside the boat there is dampness rather that a pool of water. The dampness is salty though!! I know of another boat of the same model that had the same issue with the same bolt and ended up having the keel removed. The suggestion is the factory never really tightened the bolt sufficinetly in the first place as this particular bolt is hard to access. I'm trying to find a way round having to drop tge keel as its a very slow weep as far as I can see. I'm intending to remove the sikaflex that currently covers the stud / bolt, have a good look and maybe remove the nut and washer plate. Other thoughts include putting a back nut on and trying to unscrew the whole stud from the keel. This would obviously allow me to inspect the hole and the stud properly before injecting a decent amount of sikaflex in the hole before re inserting the stud. As I'm typing this it all sounds a bit of a "bodge" but other than the inevitable cost of dropping the keel I really don't want to disturb something which in the main seems "fine". Me being a firm believer in "if it ain't broke, don't fix it". Thoughts?
Matt
Matt
