Ardenfour
Have taken previous advice and drilled pilot holes through damp patches on keel and was rewarded with spouts of liquid, some clear, some milky. The clear stuff tasted like salt water - I didn't sample the milky stuff! This is coming from low down on the keel, presumably from voids in the concrete encapsulated ballast. None of the fluids were rust stained. There is no way I can get access to the area, short of digging the concrete from inside the boat, or by cutting much larger holes in the keel. Is it possible that water has found it's way between the outer keel and the ballast and that the concrete is breaking down in some way?
Having drilled the holes and drained the water, what's the best way to seal them again? Can't see how thw inner area could be dried out (or the outer surface, which continues to trickle water) enough for epoxy to adhere well. Plug the holes with lifecaulk under pressure?
Help!
Help!
