TheoSr
On my Dartsailer I have a Webasto LO 2303.15 diesel air-heater. Must be from 1978 or so. Problem is, it starts correctly, green light on controlpanel, but after about three minutes of producing nice hot air, it stops and shows the red light. When I then put it on ventilation for 30 seconds, to cool it down, it will restart and quit again after about three minutes.
I have checked both thermostats in the heater, they are okay. The room thermostat is set at 30 degrees so that does not stop it.
The battery is new and full. I have installed new cables so it gets all the current it needs.
It takes its fuel from the main tank. The filter is clean.
I have not taken the burner out, as it does start and burn. I did check the plug.
I know it is an old beast, but (being Dutch) I hate to spend money if there is still a chance to repair it.
So any good advice is most welcome.
