kieronriley
something we have all probably used, i have never been a great fan and from what i read I'm not alone, has anyone got a product ,home made or otherwise to recommend. Thanks. Kieron
What do you want to do? Lubrication, water dispersant or rust removal? Better products to do each, but not all in one can.something we have all probably used, i have never been a great fan and from what i read I'm not alone, has anyone got a product ,home made or otherwise to recommend. Thanks. Kieron
Yes, I have a can of WD40 penetrating fluidWD40 even do a pfte dry lubricant now so very similar to the McLube Sailkote.
In the past I world also have used RP90 as a penetrating (loosening) oil but it seems like WD40 even have a 'Specialist penetrant' for that now.
WD40 comes in many more flavours than the one Water Displacement flavour that it used to.
Baby Oili would probably say lubrication
I refer you to post #4 ?I refer you to post #2
In which case, anything but wd40!i would probably say lubrication
He might want it on damp ignition leads. ACF 50 absolutely no use.ACF 50
Is it as good as Plus Gas ?Yes, I have a can of WD40 penetrating fluid
No mention of lubrication in their bumph. Never used the stuff myself, so perhaps you have direct experience.I refer you to post #4 ?
As others have mentioned, there is a hand-full of different products now all badged at WD40. The "WD40 Multi-use Lubricant" which I use as the equivalent of the original stuff is, in my experience, not a brilliant lubricant, but is good, if you spray your engine, etc, as a corrosion inhibitor. but you must shake well before use as the contents separate inside the can.something we have all probably used, i have never been a great fan and from what i read I'm not alone, has anyone got a product ,home made or otherwise to recommend. Thanks. Kieron
Oh dear, I've never had that problem.The worst thing about the WD products is that the spray container rusts in no time on a boat. I can get 6-12 months out of one and then it's a corroded mess that seems to leak all over the place.
