Aja
Just as an aside, Fiasco of Ashton had a CYCA sail number of 382C which she may well still be sporting.
Donald
Donald
Hi Metabarca,
I have checked out the Centurion Website - what a help! Yep, theres no chance i'm fitting a sail drive, no way i want to have the risk of going down that quick if the rubber fails! I'd much rather deal with the tricky manoeuvres. Photos of the new mounts would be great thanks, and you say you had someone fit it, would you mind giving an idea of price so I can shop around (no worries if you don't feel comfortable doing so!).
One thing I would like to know is did you lift the engine out/in using pulleys off the boom?
I don’t know! Lindsey Rufford of Seapower on the Orwell fitted the Beta-satisfied customer(15 years ago though!)OK thanks for the reply. I'll look into the Beta 25 for now I think. When replacing the engine, did you take off all ancillaries and use a couple of able bodies to hand ball the old out/new in or use a crane?
Hi Metabarca,
There was an article about this on the centurion site – here it is: http://centurion32.fr/forums/topic/groupe-froid-et-isolation-glaciere-sur-nos-c32/ –but yes, the recommendation was that. I have yet to fit my new fridge but hope to do so next month, and that's what I shall try...Any recommendations on the best way to improve the thermal insulation on the "cool box" - it is on my list to do but I am not sure what approach to take. One recommendation is to drill a lot of holes and fill with 2 part foam but I am a little concerned about possible side effects.
In that case I will await your report with interestThere was an article about this on the centurion site – here it is: http://centurion32.fr/forums/topic/groupe-froid-et-isolation-glaciere-sur-nos-c32/ –but yes, the recommendation was that. I have yet to fit my new fridge but hope to do so next month, and that's what I shall try...
As far as I am aware my 1972 centurion does not have an identification number still visible although I have seen photos of other centurions will a little metal plaque with the hull number on it. And many owners do know their hull number so I presume they have one too.There seems to be a few Centurion owners monitoring this thread - here is a link to a question on the Boat Design Forum in the USA, asking where the yard number (I presume he means Hull Identification Number) is located?
https://www.boatdesign.net/threads/centurian-32-yard-number-location.62598/
Were European builders using HIN's on the transom in 1973?
5th resurrection for this thread, that's got to be a record...![]()
