jaminb
Do you think there is any hope of refurbishing these to there former glory?
Looks like 3 mm of veneer ?
I'm no expert in varnish, but think that might be water getting under the varnish.Did the black spots come out after you sanded? I think they are stone punctures (trapped in shoes) through the original finish and then water has penetrated
It a wee bit cooler at 50°N than down in Oz ?A strict rule on our boat is, no shoes.
Jonathan
Exactly what I have done in the past. Brought back floor panels far worse than the OP's ?.Remove the varnish with chemical paint stripper rather than sand. Treat the spots first with diluted bleach which might shift the black or oxalid acid if they are more stubborn. Then light sand to get it all the same colour and coar with Ronseal floor varnish. Tough slightly matt finish non slip and very durable - better than conventional varnishes and much easier to apply to get a good finish.
Remove the varnish with chemical paint stripper rather than sand. Treat the spots first with diluted bleach which might shift the black or oxalid acid if they are more stubborn. Then light sand to get it all the same colour and coat with Ronseal floor varnish. Tough slightly matt finish non slip and very durable - better than conventional varnishes and much easier to apply to get a good finish.
With 3mm you stand a chance of getting rid of those black marks. Not a lot to loose in trying to sand off a mm to see what happens. I have the same marks and have noticed that in the summer the marks are a lot lighter in colour so my plan is to sand off 1mm at home and keep them indoors in the warm for a week before deciding to add new varnish. If the marks are still present my plan B is to bleach to get rid of the marks.Do you think there is any hope of refurbishing these to there former glory?
Have you tried Paint Panther? It works like Nitromors did before they neutered it.I tried that last year. I couldn't get any paint stripper to have much effect. All the ones available to the public have been completely emasculated by the change in legislation in what we are allowed to use. In the end I stuck fake teak and holly veneer down from Robbins directly on top of the old surface, and it looks like new again. I used 3M double sided adhesive sheets which are strong and waterproof, but you only get one chance to put it down. The 8x4 sheet of fake veneer was about £250 and the adhesive £50. I bought some cheap vinyl flooring to make a template - about another£20 - because my floor is all one piece, not separate boards. The fake veneer is tough stuff to cut. I found new dressmakers scissors the best.
Strict rule on my boat is footwear at all times. Stubbed toes are no fun.A strict rule on our boat is, no shoes.
Jonathan
I sort of agree with this.Do we have a no-shoes rule in our car? You may even have a no-shoe rule in your house, but your house does not move. We do no-shoes some of the time, but if a person feels shoes are important to their safety, I would never say anything about it. I won't ask them to change into boat-only shoes because I don't. Many people require all workmen to board the boat in socks. I'll be damned if I'll slip-slide around in socks or kick cleats and step on sharp bits with bare feet.
A boat is a tool to get you places and to have adventures. If it gets some wear in the process...
"Some people try to turn back their odometers. Not me, I want people to know “why” I look this way. I’ve traveled a long way and some of the roads weren’t paved." Will Rogers
I think the OP's floor looks fine, nothing a little sanding and varnish won't put right. But I wouldn't try to get deep marks out. You can damage the wood, and it's just "character."
The veneer was probably 2mm, I hardly touched the veneer the way I prepared them. Yes I did feel the dents, but did not fill them. An old trick to reduce the dent is to prick the dent multiple times with a fine needle and then add some drops of water. This will swell the dent to close to original, so will be less apparent and leave to dry overnight. The varnish fills the miniscule needle holes.Concerto your boards came up amazingly. I assume they are veneer? If so how thick? Did you feel the dents?
No external shoes down below will be the new rule if I can get the boards anything back to Concerto’s level of finish
that foot has seen better days !We aren't?View attachment 126221
