Dont do it, they say it brings bad luck to the boat and owner, if its changed, im afraid the last one forus was, it had its name changed 3 times since new in 1991, wont go into the details as to what happened though.
Dont do it, veeeeeeery dangerous, no wheres me hex? But if you must and its not a registered vessel, you dont need to tell anybody, apart from the wife, or not as the case maybe!
Arr but wot about if next lucky owner needs a bit of finance or when i nip to calais and the man on the quay sees the outline of the old name underneath me new one.
Excusemoi monseur isa voue your bateau aveez vous proofo cum this way Click bang.firmez la cell door.
Surely you haven't knicked it!! Then you must have a bill of sale? Proof of ownership? The expression is "come this way, clang!!! mind your fingers sir"
If yes, and if the boat has a radio station with its international call sign, be aware that normally a name should have been associated with the call sign (together with the EPIRB and DSC codes, if requested).
This is put into a database available to all the public services which could be involved in a rescue operation.
Therefore, you'd better update it in order to avoid confusion/doubts to whoever might receive an emergency call from your boat... or alternatively, remember to use the old name in such situations, but I'd recommend the first alternative.
An easy way to check your registration is a query in this site: http://www.itu.int/cgi-bin/htsh/mars/ship_search.sh
For communicating any change, you should check the procedure in the country where the boat is registered.
Wishing you of course to never need any rescue !!!
