Tips to Spot a Boat Scammer
FattyStan
New Member
19 Mar 2026
Hey all! I’m fairly new to boating and I’m about to take the plunge a purchase my first boat! I want to enjoy it while I can! Does anyone have any tips to help avoid being scammed or ripped off. I will definitely use a surveyor, but is there certain things I should check or is just a regular survey enough? Any help or advice is gratefully received along with a cuppa and a cake if our paths ever cross!
Have separate engine survey , make sure everything works , don’t rush your decision , it would help if you give more detail of boat. Is it sea or fresh ,inboard or out , one or two engines.
Apart from the usual 'if it sounds too good, etc' just take your time. Ask any questions you have. There are plenty of boats for sale and your original preference may change after visiting others as ours did. Personally I prefere the Broker route but we also met the seller at the boats Survey which helped our confidence. Good luck.
Thanks for that! So I’ve got a few that I’m looking at, but the one I’m leaning towards is a 1998 Sea Ray 215 Sea Cruiser. In board, single mercruiser. 5.0l
Thank you!
Thanks for that! So I’be got a few that I’m looking at, but the one I’m leaning towards is a 1998 Sea Ray 215 Sea Cruiser. In board, single mercruiser. 5.0l
Our first Mobo was a similar sizes Sea Ray cuddy, with the 4.0 6 cylinder engine on an OMC outdrive. Nice boat. We didn’t keep her long, as we wanted more room for longer stays. We chopped her in for a 25’ sports cruiser with a small galley and sleeping for 4.
Just make sure you realise how much fuel a 5.0 V8 carb engine will use!!
In a 21’ boat it will be perfectly manageable - but I would try and get an EFI or MPi engine as it will start more easily and use a lot less fuel.
It will still burn about 15-20 US gal an hour flat out but in that boat you will rarely be able to go flat out so 10gal an hr is far more likely
Yes, I’ve been searching mostly through brokers but every now and then a nice one pops up from a private seller which, as you say, looks too good to be true! Thank you for the advice 🚤🌊
Thank you! I did not know that! Great advice, thanks again 👍🏽
Nice! My plan is to do the same, use the smaller one for a few years, learn and enjoy as much as possible, and then upgrade. Thank you for replying x
You've had some good advice to get an engine survey.
I'll second that, and add that in my opinion it's because, similar to being dependent on a car that lets you down, a boat is just as bad, if not worse, because you're supposed to be enjoying yourself. Boat engine trouble gets old really quickly.
A boat like that is less about sitting around and more about doing, unlike perhaps a big cruiser.
Another thought is whether you will be trailering /Launching each time or in the water for the season.
If you're trailering do you have experience? It's not difficult but some people do find a way to make it difficult.
Difficult enough to end up having a terrible time, and it's avoidable.
If you're new to that, please do seek some instruction to make it easy.
Thank you! Yes I agree, I intend to be going out as mush as possible and less of it sitting around. I’m not far off retiring and I’ve always enjoyed being on the water but never actually gotten into it fully (which I regret) so now I’m not wasting any more time, hence the thorough research and training so I can worry less and enjoy more! I don’t intend on trailering, but I have looked into it and again I agree, I would benefit from instruction if I was to go with that option.
