clyst
I have a knot Master complete with all accessories including the original lub oil all encased in the original wooden box. I wish to sell it but whats it worth ?? Any ideas.
Shoes are a vital thing to have with it!
Spare glass, line, sinker, spinner, etc all with it ? Instructions ?
That could be the one I have vic. Its all complete just like the one in the piccy
Does anyone use these anymore?
You would if you do any long distance sailing .
Because when you're 1500 miles from land with no electrics (for whatever reason) it's reassuring to measure distance run fairly accurately in order to plot a DR more accurately than simply estimating speed and distance. For a long distance cruiser I would suggest a mechanical log is pretty much top of the list of stuff which should be carried even though hopefully it won't need to be used. Along with a sextant (a what?).
Cheers, Brian.
Why do you need to measure distance run accurately when you are 1500 miles from land?
When I crossed the Atlantic there were 3 GPS systems on board - one powered off the yacht's battery (two batteries on board) and two with internal batteries (plenty of spare batteries carried). There was also an electronic paddle-wheel log drawing less than two milliamps. Also a sextant.
I can see that people like the Pardeys, who have no electrics, would want a mechanical log but the rest of us mere mortals can manage without. Which is probably why they fetch such low prices on ebay.
By the way, if you are interested in buying one - I have two gathering dust in my wardrobe.![]()
And If Uncle Sam turns it off??
If you trust your GPS (and backups) then why bother with an electronic paddle wheel log or a sextant both of which (using your own logic) would also be redundant whilst the GPS functions? Using the same logic as yourself I like to carry a mechanical log. It'll probably never get used (like the liferaft and EPIRB) but it makes life simpler if we ever find ourselves having to navigate using traditional methods.Why do you need to measure distance run accurately when you are 1500 miles from land?
Cheers, Brian.
So that you can plot your position using two sun sights and the distance beween to give a running fix, often called sun-run-sun.Why do you need to measure distance run accurately when you are 1500 miles from land?
I'm not arguing in favour of being foolhardy, just for a realistic assessment of the likelihood of something going wrong and how capable you are of coping with it.
