ianj99
Split charge diodes + smart regulator sensing the house battery works well for both boat and camper.
Simple ignition switched operated split charge relays will allow heavy current flow from the house to the starter battery during cranking.
So the simplest and best solution IMHO is to activate the relay via an oil pressure switch (normally open type, not the usual normally closed warning light/buzzer type).
(Its simple enough to fit an an additional small relay with changeover contacts to drive the main relay from the existing oil pressure warning light switch)
