vas
Sounds good. You obviously limit the pump rpm by the pulley sizes to keep pump max rpm below engine max rpm
Measure roll period with an iPhone app. I use the Sleipner one but there might be others these days. Do it when the ferry goes past with hand brake turn
As regards Porto comments on downsizing the fins, I wouldn't worry about forces/loads. The hydraulics will nicely limit that via pressure relief valve (which you must fit imho), and the force needed to anti roll the boat is a constant regardless of fin size of course. But the big Q is can you succeed with STAR? If you can, then keep them biggish (I like your drawing) because the only reason for big fins on a P boat is STAR. If ultimately you cannot achieve STAR then make the fins half the size because you can always speed up if you need more anti roll torque.
So, the way James and possibly yourself use the pumps is that they are permanently connected, so as soon as you fire the engine, you have oil pressure (well you need it for thrusters and windlass, right?). I don't but that means that as long as the engine is running you might as well have the stabs on!
This way I could easily do it in a permanent setup as well.
Just feel that the el will be less hassle, plenty of space to fit it where as only got 150mm between engine pulleys and tanks so not so easy to play around there... will have a nose around today when I remove the salon floorboards to start working/servicing engines.
ohhh blimey, you're so fast J.!I'll report back on inverter 3ph Vas. Before uk leaves the EU![]()
cheers
V.
