Pleinmont
Hi
Recently I've been getting the odd intermittent water/coolant temp alarm/flash warnings from the dashboard panel at around 3000rpm but the Temp Gauge (dial) remains as calm and predictable as always (circa 82deg when cruising, 85deg at WOT).
Through process of elimination I think the engine is fine and cooled ok but maybe the alarm/light switch or connector is faulty.
I found the sensor for the Gauge on the thermostat housing (confirmed by unplugging when engine at temp and dial drops to 0) but I cannot find another other one for the alarm/light.
The exploded diagrams online show both of them side by side on the thermostat but mine only has one screwed in with the other hole filled with a blanking plug...
Does anyone know where another coolant or water temp sensor might be located on the engine?
Unless all my alarms/lights and gauge are fed by the one sensor (which seems odd).
Engine is TAMD41P-A from 2005
Thanks IA
Thanks IA
