JohnL
I removed my Sail Drive to change the seal after twelve years, it did need replacing also the retaining ring was rusting badly [missed by the surveyor]the job was not difficult. But then I found the paint was flaking of the leg under the flap where it cant be seen, fortunately only slight corrosion, this job is now getting bigger.There is also some wear on the gearbox splines [quote over £300] water was found in gearbox oil, oilseals gone prop shaft worn [£360] for new shaft. I must admit I was one who poh pohed the idea of changing the seal every seven years I now believe it should be done regularly. I have only owned the boat seven months Volvo is turning out to be expensive.
