Doryjohn
New Member
I was having white smoke/steam problems with Volvo Penta TAMD41. I spent over £3000 with the experts trying to solve the problem - injectors and high pressure fuel pump serviced and a brand new water pump at £750 plus all the usual system checks and cleaning etc etc.
I eventually identified the problem. A small split in the sea water filter allowed air to be sucked into the cooling system. This reduced the amount of sea cooling water but was just enough to keep the engine at the correct temperature. However, the reduced sea water was much hotter than it should have been and when it mixed with the hot exhaust it turned to steam. The faster the boat went the more steam. All fixed with a new filter box for £100.
So if you have smokey steam check your water flow first!
