Volvo Penta Ignition
glynsue
15 Dec 2014
Herts
Starting-Running Volvo Penta 2003
I have noticed that when I turn the ignition on ,a red battery light shows, I go through the start
sequence and the Volvo 2003 3 cylinder engine starts first time, and runs smoothly
the other two lights do not light.
This is the first Volvo 3 cylinder I have ever had, so please can you help a novice
Glyn Williams
Skye
PaulRainbow
16 May 2016
Suffolk
Glyn Williams
Skye
Do they come on when you press the "test" button, If not, first job would be to check the bulbs Glyn.
EDIT Ignore the test button, it only checks the buzzer.
rogerthebodger
3 Nov 2001
If you rev the engine doe the red light goes out or does it stay on.
If it does go out it shows the battery is being charged if it does not go out there could be a problem with the alternator
glynsue
15 Dec 2014
Herts
Hello all,
red goes out when engine starts.
I will try test button later when I am in the Marina.
I did not know if this engine has an alternator
as only gauge fitted shows RPM, no charging details
or temp.
As I admit , the sailing bit is fine, outboards are ok Old Volvo 3 cylinder diesels
are in a world of there own
rogerthebodger
3 Nov 2001
I would recommend that you take some pictures of the engine front top and from the rear.
Is the engine started using a battery if so do a voltage measurement of the battery with engine running then stopped then compare the voltages
Stemar
12 Sep 2001
The VP2000 series has a bit of a reputation, mostly from people who don't know the correct starting procedure. I had one for years, and starting was pretty much first time, every time, though it did need a bit of churning when there was ice on the deck.
You can download the owners' and workshop manuals from here
VicS
13 Jul 2002
Glyn Williams
Skye
Al three warning lights should illuminate when first switched on .
They should all go out when the engine is running
The audible alarm should be tested after switching on .
Read your owners manual.
If you have mislaid the manual you can download one from VP's website at Manuals & Handbooks | Volvo Penta UK & Ireland ( you only need to enter 2003 in the "product designation box" )
glynsue
15 Dec 2014
Herts
I will take pics Friday when I check the boat (Buchanan 24) and
find the engine spec, and re-submit my plea for help.
I copied my start procedure from the YB , ie Pump throttle twice while in neutral,
pump the stop controls in and out twice, leave throttle open fully and away she goes.
Glyn
Skye
Tollesbury
VicS
13 Jul 2002
Doesn't the test button only test the audible alarm. See the schematic for the panel in the owners manual
VicS
13 Jul 2002
Glyn
Skye
Tollesbury
The correct starting procedure is described in the owners manual.
glynsue
15 Dec 2014
Herts
A general point, is it normal on my model of engine to have no gauges, no temp, no charging rate
just a rev counter.
Glyn
Skye
VicS
13 Jul 2002
just a rev counter.
Glyn
Skye
There are two possible panels.
The basic panel like yours or one with temperature and oil pressure gauges and a volt meter.
Also keyed and keyless variants
An auxiliary panel with the gauges may have been available as an accessory.
Stemar
12 Sep 2001
I've a feeling that the control panel is no longer available, but you could buy and fit the instruments separately. You'd need to change the sensors on the engine, as the ones you have will almost certainly be simple on/off switches. As for a voltmeter, I'd connect it between the switched side of the domestic battery isolator and the domestic -ve, as that will also give an indication of the state of charge. >12.5v is good, below 12v, time to reduce the load, and if it's still below 12v, time to get some charge in. Those are figures for flooded lead-acid batteries, other types may be different - completely different for LiFePO.
Alex_Blackwood
19 May 2003
Fareham
Posters are referring to the sate of charge and how to check it.. Is it not the case that the fault lies with his temp. and pressure lights/sensors. the charge indicator appears to be working indicating that the alternator is operating.
Edit:- Has he checked that the bulbs are OK? :unsure:
glynsue
15 Dec 2014
Herts
Hello All,
a serious bout of flue stopped me from carrying out all the helpful hints till now. All three of the lights on the panel now work as they should, I cleaned, checked and remade all the connections. I have now noticed a very faint blue haze amongst the white exhaust leaving a faint but noticeable oil slick. The engine starts well and runs smoothly. What can I do please
PaulRainbow
16 May 2016
Suffolk
Hello All,
Go sailing.
Pete7
11 Aug 2004
Gosport
Go sailing.
Indeed, along with an Italian turne up. Ours got one unintentionally when we raced back across the channel with a F8 threatening. We made it and the engine ran perfectly after some 10 hours of hard motoring. Do not put synthetic oil in it either, nice basic oil each year and if it hasn't been done recently 1.5L for the gearbox would be a very good idea.
