27 Sep 2021 #1 T TerryA Active Member Joined 17 Mar 2019 Messages 60 Visit site Quick question. What voltage is the power supply to the DP290 drive? Just looking at the battery and wiring chaos and trying to dicide what is going where, Thanks
27 Sep 2021 #2 S scottie Well-Known Member Joined 14 Nov 2001 Messages 5,511 Location scotland Visit site Is power not just 12v required for lift and or trim Wiring diagram in w/s manual
27 Sep 2021 #3 Momac Well-Known Member Joined 7 Feb 2008 Messages 7,603 Location UK Visit site You could check the relays on the trim pump which should have the voltage marked on them but I would be surprised if it's not 12 Volts.
28 Sep 2021 #4 Moodysailor Well-Known Member Joined 7 Sep 2020 Messages 956 Visit site I'm confused? What voltage are you asking about? For trim? For shift on EDC engines? For the engine itself? The DP drives do not require any voltage to operate, they are purely mechanical.
28 Sep 2021 #5 T TerryA Active Member Joined 17 Mar 2019 Messages 60 Visit site Thanks. It was the trim I was asking about. It seems most likely to be 12v which leaves me with some more investigation.
