julians
Earlier this year I had a starting problem where it would appear as if the battery was on the way out. Ie if I'd left it plugged into the charger and then start, it would fire up and start just fine, but if I left it for a day or so not plugged in to the shore power , it would be completely dead when you turned the key,no click, no flicker of life on the dash, no voltage on the dash volt meter - dead.
So we put a new battery on it and it seemed all fine,started fine after being left for a few days.
Now I've been away for a few weeks and it's is completely dead, nothing going on when you turn the key, no clicks, no volts etc, despite being plugged into shore power.
Now I'm guessing it'll be a dodgy connection at the starter battery master switch or on the ignition key mechanism.
But before I go pulling it all apart searching for corroded connections, has anyone seen similar on a vp d series engine?
This is ona 2007 vp d4 260.
