Volvo penta d1-30....new problem
billyfish
6 Oct 2020
Well I'm baffled...last year now and again the engine wouldn't shut down , if I wiggled the switch up and down it would eventually shut down . Easy I thought, fit a new switch, now fitted, no difference, won't shut down . This is a panel with the left switch does glow and test the right switch does shutdown - off - ignition on. I've replaced both switches and both relays in the MDI box although I'm not sure it's the original as the start relay is out side the box . I've traced the wire from the panel to the shut off solenoid and got continuity. On the back of the switch with 6 terminals 4 are connected 3 one side one and one in the middle pole, which is the shutoff violet wire on the other side. However when operated no current is getting to the violet wire. I took a photo before I replaced it so I know the wires are right. Not sure of the nxt step. HELP PLEASE...
VicS
13 Jul 2002
OK so I have a MDI box which ,I think , someone has bypassed, with a 70amp starter relay , not been a problem thus far but now can't shut the engine off by the panel, anyone know if the shutoff also goes through the MDI. I've changed the 3way switch but not getting voltage to the shutoff solenoid. See picture of MDI add on. Which ,following a few sparks, must be connected straight to the battery.
Firstly I think you are mistaken in believing you have a MDI system. The photo in your previous post shows a relay bolted to the outside of a conventional relay box. The D1 series of engines only had a MDI from the B variant onwards
I have the workshop manual for the early D1 engines but it is not much help because it does not show the stop circuit ( violet wire) in the diagram for the panel without a key switch !
I do not follow your description of the wiring of your stop/off/on switch, "On the back of the switch with 6 terminals 4 are connected 3 one side one and one in the middle pole, which is the shutoff violet wire on the other side", but it should be easy to work out which wire to connect to which terminal.
I'd expect a red wire ( the incoming power supply) to be connected to one ( probably the middle one on one side ), Two red/blue wires to be connected to another on the same side and the violet wire to be connected to the third terminal on the same side., but there might be something a bit clever going on to keep the panel warning lights buzzer and tacho energised during the stop procedure although I don't see why there should be
Can you post a diagram showing how the wiring is connected and/or the photo you mentioned. I suspect you merely have the violet wire on the wrong terminal.
billyfish
6 Oct 2020
Thanks for your reply, I agree, something is not right but this is the photo I took before I changed the switch, all I can think of now is the switch i got must be the wrong type.
VicS
13 Jul 2002
That's not quite what I was expecting.
According to the parts list the switch is part number 3586251. What did you buy?
The switch in the photo looks like it might be the same as the glow plug and alarm test switch , but according to the parts list they are not the same
All I can suggest is that you determine which terminal becomes +12volts when the switch is in the "stop" position and move the violet wire to that terminal
billyfish
6 Oct 2020
Yes, couldn't find it on the parts list either and I can't find a wiring diagram for my setup. I took the old switch to a switch shop and they changed like for like, I thought. The difference between the two is the other one is momentary up and down and this one is momentary just In the up shutdown. Ignition on in the down. I can't get current to any pole on the left side wherever the switch is positioned.
VicS
13 Jul 2002
The switch should be momentary on in the stop position but stay on in the power on position.
No you wont get power to any terminals on the left side, only on the right as it is wired. The two sides are the separate poles.
I dont understand why you have a double pole switch or why there are so many red wires on it. I expected to see just a single pole switch such as this Furneaux Riddall SPDT ON -OFF-(ON) MOM switch
On / Off / (On) Momentary Toggle Switch 20A SPDT
I have attempted to edit the wiring diagram to show what I expected for switch10 and the wiring to it but you have too many red wires.
I think this must be solved "hands on" rather that remotely via a forum
billyfish
6 Oct 2020
Yes I got the switch from them. Back on board now , going to find a live to go to that side of the switch. Will report back . Thank you
billyfish
6 Oct 2020
Yes ...by moving the two reds to the bottom of the left side ot works but I still don't know what they do or how it worked before
VicS
13 Jul 2002
I'd have put the Violet wire on the bottom right terminal but if it now all works as it should the problem solved
I'd want to find out what all the red wires are.
billyfish
6 Oct 2020
So that had something to do with the charge circuit as I got intermittent beep alarm on the battery, so made a jumper across..trying it now
billyfish
6 Oct 2020
Now the battery alarm keeps going off have I buggered the diode in the alternator. It's still charging. But from 14.09 to 14.19 volts 14.22 at the battery
