The Last Englishman
Hi All,
Have just de Winterised my Two AQ131C volvo Penta engines and have a problem with one of them
Normal process to start engines is to pump Throttle a couple of times to prime the Carb put Throttle into neutral with a little bit of throttle and start the engines.
One engine started fine as normal the other just kept turning over and not starting
so to cut a long story short compared both engines and found that the one that wont start is not getting any fuel when priming, so added a bit of fuel to the carb and engine started and ran as expected with fuel entering carb as normal when throttle was moved
engine ran for 20 minutes before i stopped the engine. when trying to restart it it fired up good as gold and ran as normal.
When trying the priming process again no fuel came from the Priming nozzle so when the engine cooled down it did not start again until i added a small amount of fuel direct to the carb
So Fuel Pump seems ok, Fuel is getting from tank to carb when running but no fuel is getting to the carb when priming
Can anyone explain what they think is happening, what i should check to ascertain what is wrong?
I dont have pictures ATM (forgot to Take them) will do so over the next few days if that will help
Many Thanks for your help in advance
TLE
TLE
