Volvo penta A5 original or aftermarket?
Mario Triker
28 May 2022
Hi there sailors, has anyone tried replacing worn original v.penta propellors with aftermarket ones, as volvo penta ones are ridiculously priced . Did any who did this loose performance? Which brands would u suggest? Thanks for any feedback anyone can give me on the matter .
Momac
7 Feb 2008
UK
I did buy some aftermarket props with no issues.
Can't recall a particular brand.
Scubadoo
Hampshire / Solent
Yes, I have been using aftermarket Volvo Props since 2010 and are just the same as the Volvo originals in terms of performance and perhaps more durable. If I recall correctly before Volvo went to J series props ,the blades on the aftermarket equivalent were stronger. The hub on the J series has no flexibility hence if you hit something the shock goes through the outdrive gear box instead of the prop hub, not the case with aftermarket I use (when I last checked).
Brands: Powertech which I don't think are available anymore, I am using Michigans at the moment, been on this set for at least 4 years without issue. I get a good price from Streamlined Propellers.
