boatmike
The manual for the md7a specifies using the dip stick hole.
And yes.. I know now it should have been done in the autumn
I smiled at that Stu! Not exactly helpful advice saying you should have done this earlier is it? In an ideal world everything goes to plan. On planet Earth shit happens! In my case the boat was lifted out in sub zero temperatures with ice on the decks..... No opportunity to run engines with boat afloat. However I think I may well have overlooked the obvious due to the fact that I was looking at access points near the sump when there is a pipe installed for the purpose terminating higher which in my case is right under a cupboard! Oh well as I said before, not to old to learn even if I feel a bit of a twat for missing the obvious. In my defence the Volvo manual is not very helpful in pointing out that this pipe exists...... Thanks to Trundlebug for pointing out my schoolboy error....
