Volvo IPS2B oil pressure fluctuating.
stelican
25 Nov 2004
fareham hampshire
We are experiencing low oil pressure and fluctuation at idle which normalises and matches other drive when revs reach 800 in gear and above
tested with manual gauges and similar readings.
Has anyone experienced this and how corrected. Boat is now ashore for winter.
50 PSI difference
madabouttheboat
20 Jan 2005
UK, but for Covid it's England
50 PSI difference
Does your ips have the hoses that go up to the remote filter housing? If so, are the pipes the right way around? Seen oil pressure alarms caused by pipes that have been installed the wrong way around. Check against other engine.
oldgit
6 Nov 2001
Medway
A friend has just had a IPS repaired.
Surveyor checked the pod oil condition and said internal pressure due to water ingress had forced out oil when dipstick was released.
He suggested that it was almost certainly the prop seals had failed . 100% correct.
