Volvo D6 350 PITA
Ky343
4 Apr 2025
I am new to this forum and the Volvo D6 350s. I have twin diesels with DPH-A drives. I recently pulled it out of storage to change the impellers. This went pretty well considering it was my first set on this type motors. I removed the fuel filters along with a couple water lines during this process. After installing them I first started the sb engine. All was well. I tried the port. Nothing. The port side gauge cycled through all of the warning lamps, stopping on the orange triangle indicating a fault. Area in tach for a fault code is blank. None of the port side gauges are activated. Whenever the key switch is turned to the start position, there is no sound whatsoever. The triangle continues to flash on port gauge even after key switch is turned off. It will do so until the battery switch is turned off. Also, the tilt/trim does not work at all on either drive. No sound at all. With both key switches on I tried holding down the N button and pushing the trim button. Nothing. Batteries are less than a year old and fully charged. Any input will be greatly appreciated.
footsoldier
4 Aug 2006
UK and France
I recently pulled it out of storage......whenever the key switch is turned to the start position, there is no sound whatsoever.......
Big clue there. I would be checking all the connections in the wiring between the battery and starter, where you are likely to find a connection that is corroded
