Mark0474
Hi All
I have a volvo penta D3 220 which has suddenly started to give me lots of troubles. Here is a summary of whats happened and checked.
1.I had a faulty injector which was replaced and tested, engine ran well without troubles during sea trials.
2. Engine just suddenly stopped after an hour of running at a constant speed, no alarms, knocks, smoke etc, it just stopped. Kill switch checked, two red fuse buttons checked and all ok.
3. It was difficult to turn over so replaced the starter motor and also replaced the batteries as they were old.
4. Engine turns over but not starting, had a few sensor errors, sensors checked and cleaned and errors went.
5. Realised that there wasn't any fuel pressure on the gauge.
6. Replaced the High pressure pump
7. Replaced the fuel pressure regulator and the fuel pressure sensor (5v supply to this sensor)
8. Cleaned all fuel lines, replaced fuel filters, water separator, replaced fuel in the tank.
9. I keep getting strange sensor failures and feels like I'm just going in circles
10. Also checked all the relays.
11. The key and barrel were renewed as the key was sticking and corrosion on the barrel.
So where I am now is lots of new parts, engine still just turns over and will not start. I had Volvo technician arrive and he just said there isn't fuel pressure common rail, then stated the head was damaged and needed to be replaced. This I'm not sure about at the moment, I just cant figure out why there isn't any High pressure fuel coming to the injectors. The feed pump is working and runs as soon as you turn the ignition on for a few seconds then stops.
The Fuel pressure sensor just shows _ _ _ and no readings. My thought is that the pressure sensor is linked to the fuel regulator and once it detects pressure in the line, it opens the valve and then the system is pressurised and therefor the fuel gets to the injectors.
The local Volvo guys just want to take the engine out and remove the head and won't discuss doing anything else.
I am also looking for a wiring diagram for the D3 as well as it will help with the wiring loom and I also would like to know if the ECU (bosch metal casing) should have a ground wire as the boat is fibreglass. I think that it has a common ground but cant find where its located.
Thank you for any help,
Mark
Mark
