Victron Centaur as power supply
Sea Change
13 Feb 2014
Centaur connected to shore power, charging a bank of batteries whilst some small lights etc were running.
Due to some suspected problems with the batteries, I disconnected them and found that the lights stayed on. But after about 20 minutes, the power cut out.
Is this what you'd expect if you used a Centaur without a battery connected? I hope I haven't damaged anything...
PaulRainbow
16 May 2016
Suffolk
I don't think the Centaur has a power supply mode, so if the batteries are disconnected it will still be using its charging logic, which would likely be the reason it cut out. I doubt anything will have been damaged.
VicS
13 Jul 2002
Certainly no mention of a power supply mode in the literature.
