muzzaman
I am looking for a little guidance in relation to an 80w solar panel that I am installing. If anyone can help that would be great!
I want to be able to disconnnect and remove the panel easily and am therefore thinking about a through deck connector (2-pin) mounted somewhere in the cockpit.
The rating for the solar panel from the datasheet is -
Nominal power - 80w
Max-Power current - 4.45A
Max-Power voltage - 18v
There are numerous through deck connectors available but I am unsure as to which rating is suitable given my requirements above. I also want to install a plug/socket that can cope with a possible upgrade to a larger panel at some point.
If anyone can help with the most appropriate rating for the socket or even suggest one that would be really useful.
Many thanks in advance.
Nominal power - 80w
