mhember
Hi,
Our Endurance 40 has Plastimo dorade vents.
(Plastimo 16933 Dorade Box Cowl Vent - 205 x 335mm)
These have proven less than ideal; they don't ventilate the boat especially well and in any sort of upwind weather we have to plug the vents as they let in rather more water than I'd hope.
I think they have been fitted the wrong way around which does not help. Finally, they have not proven very robust and the occasional passing sea boot tends to crack the screw holes.
I'm looking for a recommended replacement; I'm concluding that Solar powered ones will not be sufficiently weather proof, and ideally I want something lower profile probably with a built in stopper that can be shut when needed. I suspect I'm going to need to add a 12v fan in the cabins where we need a bit more air when occupied.
Anyone got any suggestions for good, robust, low profile vents?
Thank you!
Thank you!
