Vendee Globe and Alex Thomson / Hugo Boss
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
Having seen AT video of the damaged structure,. the "un coup de strat" wording used yesterday by the designer does not really seem appropriate
You are right, my interpretation, he does not say anything about the size.
He says it needs "un coup de strat autour de la fissure", litt. add a bit of lamination around the crack.
In case of significant damage, "un coup de strat" would not have been the proper wording; if they are really telling the full story of course.
mainsail1
27 May 2008
Now in the Med
I thought that these were in the hull rather than the longitudinals though...
You have greater knowledge on the precise location of the failures but surely it showed what a pounding the bow takes and a lot of extra stiffening should have been added to make sure it could take the punishment of a Vendee?
flaming
24 Mar 2004
I think there's something odd going on here to be honest. If we take Alex at his word something "felt wrong" with the boat the day before yesterday and on doing a full inspection he found the damage. I can't believe that he hasn't been into the front of the boat since he passed through Theta, and since then he's had moderate reaching conditions.
So either the boat has been damaged since Theta (or possibly the heavy upwind conditions in the 1st 48 hours) but Alex didn't notice, or it acquired that damage in very gentle conditions. There's a conspiracy doing the rounds that he knew about it and they were waiting for a quiet patch to fix it, but I don't buy that, it doesn't fit with the taking 6 hours nap whilst the team worked on the repair plan, or the keeping the lead for a week pushing hard whilst knowing that sort of damage was up front....
I'm also struggling to accept that Alex could sail for a week at full speed with that damage without noticing. They do a lot of boat inspecting as a routine, and surely you'd notice that lack of stiffness.....
The only thing I can think of that's different could be the fact that the boat has been across the equator, so could there be an element of temperature involved? Was it maybe too stiff and thermal expansion left the structure with nowhere to go?
But the reported conditions when it let go don't really support the "just didn't get the peak loads right" hypothesis... Fatigue maybe....? But you wouldn't expect many different break points from fatigue would you?
Agree it definitely shouldn't break like that, but I've got a funny feeling this may well end up as a case study for something unexpected.
dom
17 Dec 2003
I'd so love to be wrong, but I just can't see how that sort of damage is repairable at sea - not in advance of the Southern Ocean.
I also don't see how that happened unbeknownst to Alex; when a racing boat takes a really bad fall off a wave - what it looks like to me - it is normal to spend a couple of hours micro inspecting the structure. Odd.
Whatever happened, such a shame, really sad. :(
Edit: I just love Alex's attitude when backed-up like this, true grit and all that.
Perhaps if he has to retire early we can pike his boat and make him Prime Minister for a year or two :)
cherod
2 Dec 2018
( i hope i am not wrong ) i cant see what is so difficult in the repair assuming access is possible and he has some tools , maybe physically difficult but not technically , as mentioned yesterday in official release , cutting and bolting on some carbon " plates " , ( effectively sheets of carbon ) , drill holes , bit of prep , slap on plenty resin and bolt into place , and wait ,,,there , easy ..(y)
savageseadog
19 Jun 2005
Contamination, keeping the repairs clean and dry could be difficult
cherod
2 Dec 2018
just watched the 2nd up date ,,, got to take my hat off to that guy (y)
( surely that puts to bed the argument of if it is a good idea to carry a grinder on board !! )
burgundyben
28 Nov 2002
Niton Radio
I guess the adhesive he has onboard is sonething like Sikapower 1200 in the double syringe kits. We put dozens of those in wind turbine blade repairs.
I'd love to see the FEA results in the damaged areas and the D/PFMEA work for those areas.
Airscrew
1 Feb 2015
Hamble River and Nidri - Ionian
Yep,
methinks there will be a host of race yacht design houses and CFD specialists at Uni etc who will try and build a model and replicate a (load) scenario that might cause that damage
