Gordonmc
Velvetdrive G\'box anyone?
Has anyone with a Borg Warner Velvetdrive gearbox experienced the same problems as me?
After a couple of trouble-free seasons I have twice lost drive, indicated by an increase in engine revs and slowing down. This gets progressively worse until the boat is dead in the water.
On checking the ATF level I find its gone.
It happened at the weekend when I was motorsailing but I was able to set the tiller and go below to fill up (urgh). But where could the ATF be going? There are no signs of leaking from the box.
The only other possibility I can think of is the casing might have failed somehow and the fluid is exiting through a cooling port. If it was going through the stub shaft bearing there would be an engine drip tray full of the stuff.
Any ideas?
Any ideas?
