Vee Birth which way up?
TerryA
17 Mar 2019
Simple question. Two bodies in a vee birth which round is best, feet to bow or head to bow? And do we put in that filler piece or not?
burgundyben
28 Nov 2002
Niton Radio
We have feet to bow and the filler vee piece inserted. Had to alter the vee piece to make the cushions the same level and also modified a duvet to a 'vee' shape.
Were the same, feet to bow, 2 adults and a wriggling six year old in the middle. Duvet underneath and another on top, comfier than home!
CM74
14 Oct 2021
Definitely feet to bow, especially as in a lot of small boats at least, it's much lower at the bow end so you couldn't sit up!
johnalison
14 Feb 2007
Essex
It tends to get stuffy oop front, so that’s the best place to stick one’s feet. The filler is optional and depends on the degree of friendship if there are two residents.
Poignard
23 Jul 2005
South London
The boatbuilder decided it would be heads aft, and fitted reading lights to suit. But the forward end is so narrow that head forward would be very uncomfortable.
But it's not important since the forward bunks are neve slept in, the cushions stay at home, and the bunks are a dumping ground for spare gear, toolboxes,etc
Daydream believer
6 Oct 2012
Southminster, essex
Depends how far apart one wants to put their knees ;)
That being said we tend to sleep one up front with most of the clothing etc to one side. That leaves the 2 saloon berths free & there is less disturbance in the night if one gets up for the inevitable visit to the heads. Being skipper I have the aft berths & keep my clothes in bags on the spare bunk next to me. Trying to keep stuff in bins under seating is a real pain as it means moving stuff all day long.
Under way, or during the day, bedding, clothing etc. goes up front leaving the saloon free
Normally I sail SH so all my clothes live up forward & my aft berths are clear so I can spread out as much as I like. ?
blush2
26 Dec 2008
I must be the odd one out, we always put the infill in and slept head to bow, simply because it was easier to get out of bed for a pee!
Started sleeping head to bow because initially there was no anchor locker, chain etc and the bows were higher than the stern. Sir wasn't comfortable so we slept that way round. Also easier to get to the heads and nobody sleeps with their head against the heads compartment bulkhead! Its a pretty large V-berth so there is no infill.
LONG_KEELER
21 Jul 2009
East Coast
Exactly. Probably appeals more to the higher age group of sailing folk. I find a nightcap can offset any extra noise from the anchor chain.
ashtead
17 Jun 2008
Surrey and Gosport UK
Maybe depends on size of berth and how the reading lights and shelf’s position. Our bow berth is fairly wide but never sleep as couple with head in bow but if alone or sleeping on passage say I do sometimes sleep across the berth diagonally. My estimate is you need a 45ft plus boat to sleep with head in bow but I guess depends how far back the bow cabin is in design . Nowadays new boats seem to have much broader bow cabins in the beneteau type design which might be the way to go if looking to adopt this approach plus you get some nice cabin windows . Worse thing is offset bow berth though.
Stemar
12 Sep 2001
In our Snapdragon 24, we slept feet to bow, because there's more room that way - feet take up less room than shoulders. The infill was used until Milady's limited mobility meant not having it made getting in and out of bed easier. We always used single quilts as anything that was narrow enough to fit the pointy end was too narrow to keep feet warm. Two thicknesses meant toasty toes :)
Having said that, we've slept heads to bow when dried out on a sloping beach and even widthways once, on a horribly rolly mooring. (Top tip - avoid Omonville la Rogue in an easterly or northeasterly wind and for a day or two afterwards!)
LiftyK
3 Sep 2015
Feet to bow. Enter by facing astern a few feet away from the bed , support yourself with your arms, then swing back one leg and rest on your knee. Then swing back the other leg. This eliminates the need to crawl in then turn around, especially useful if your partner is already in and snoozing.
LONG_KEELER
21 Jul 2009
East Coast
Or just open the forehatch and go vertical if a quick exit or entry is required.
