Twister_Ken
Boots, dunno, but any school stinks lab.
Know any teachers?
Know any teachers?
OK, some ideas for testing for copper:If the boat were mine I would be looking at trying some simple chemical tests to determine if there was any metallic copper exposed on the surface. A quantitave test would be nice to do but would involve fairly extensive laboratory facilities or a substantial bill from an analyical chemistry laboratory.
Could you give me an idea of any tests that you had in mind? (I had an old fashioned grammar school education and thus learnt Latin, Classics, History etc - Science was not something that in those days was seen fit for gentlemen to learn about.............)
The short answer is 'no' - they have not given me a complete refund, merely refunded enough to make me believe that the alternative (which was Court action) was not worthwhile. The money refunded was only about 1/3rd of the total cost of the work, including two separate applications, six or seven scrubs a year for the last four years, etc etc. Nothing has been paid for the time and angst over the whole matter. Had it been Court action, solicitors had already advised me that I should claim for the whole cost over the years, suitable allowance for time and trouble and so on.
Apologies if you have already done so but I think the whole saga should be referred to "Aquarius Marine Coatings" They are apparently the manufacturer and should be able to put one of their technologists on to the case.Any ideas anyone?
That sounds a likely explanation. I wonder if the person who applied it tried to 'eke out' the last coat by tipping in a bit of extra resin.I would lay money that the hull has a covering of epoxy over the copper, most likely caused by the copper powder not being constantly mixed during application.
It has worked for me, and I believe, a good many others. The photo is of Galadriels rudder 8 months after its last scrub. The rudder I believe is a high fouling area as it is exposed to more sunlight. You will see some beardy type grass near the water line, this we find is common, we do not get any marine life, only grass and slime.
I dont think you can get away without drying out and scrubbing, although some have, but as you will see, like anchor and col reg threads, there is a broad difference of opinion.
I applied the coppercoat myself, and yes you do have a comeback if it is done professionally, but if you do the prep as it tells you, and you stick exactly to the instructions you can do a job equally as well as any professional, if not better. After all its your boat, if the lad who is rolling it on at the yard is working his notice, has had a row with his girlfriend, or got a hang over, the last thing he cares about is your boat.
