lustyd
Yes I get that. Safety backups take many forms, you know that. A three point fix being a specific requirement is borderline arbitrary. Is GPS mandatory?
Careful that you don't mix up equipment necessary to be carried with what's done with it! Don't think anyone has said a three point fix is a specific requirement. But the necessary tools are available should it be required.Yes I get that. Safety backups take many forms, you know that. A three point fix being a specific requirement is borderline arbitrary. Is GPS mandatory?
For coded small craft like training boats, the only option was a mini-ECDIS. A chartplotter wasn't enough. So needed auto chart updates, auto backups, ability to enter 3 point fixes and do those to be used as current position, hardware self test, vessel data recorder, certified hardware etc.
UKHO and MCA really need an affordable system in place for small commercial vessels, before they pull the one everyone uses.
No need to have a supply issue if everyone switches to Imray, simply show the sales stats and you will have been right all along.I wonder whether they will have a 'supply' issue like calor gas. Don't print any for what ever reason, claims no one buys them therefore drops the product .....
If I require new charts Imray will be top of my list now.
It's people like us who don't buy new charts, who are causing the problem.I'm pleased to read that. So much so, I may well go and grab me a handful of 'retail therapy' in the shape of..... cough, cough.... new charts I actually pay for!
Half of mine are B&W in fathoms. With cutesy little pen 'n ink landscapes along the margins. Anyone else remember them?
Remember them! I’ve still got some. In fact one or two of the folios that I have for our current Caribbean sailing adventures still have a couple of fathoms charts in them!I'm pleased to read that. So much so, I may well go and grab me a handful of 'retail therapy' in the shape of..... cough, cough.... new charts I actually pay for!
The notes for this extra-ordinary book were made by Ewen Southby-Tailyour during a thirteen-month survey of the Falkland Islands that he made in 19 78-79. Little did he realize then that they would become the source of the detailed landing plans drawn up by the British task force in 1982 when the Islands were repossessed.
Sadly, maps of the Falkland Islands that were current when I was last there (2010) are not really up to modern standards; I think they were based on 1950s and 60s surveys. My former employer has offered to do survey work but unfortunately, up until 2011 (when I retired) the Falkland Islands Government had not been able to find the necessary (substantial) funding. I think that they have done some local surveys since then, but no comprehensive mapping to modern standards. The existing maps are not bad, but lack detail, and are referenced to a local survey datum rather than to a global one, as far as I recall. But I am out of touch with the current status.That's exactly what Lt/Col Ewen Southby-Tailyour did when commanding a detachment of 'Royals' some time before the Argentinian invasion. His pilotage notes became the 'Falkland Islands Shores' and made a major contribution to the success of the Task Force landing and the insertion of Special Forces.
As far as I know - and I may be out of date - the problem arises because of the sheet-centred nature of the data. Many charts are the subject of international agreements to share data, and these agreements work on a sheet by sheet basis. There are also issues to do with Chart Datum; managing things on a sheet-by-sheet basis means that a sheet can apply the same chart datum across the whole sheet, but an adjacent sheet may have a different datum. As the datum is usually LAT, it does differ from place to place. There are even a few charts (the River Thames comes to mind) where I understand the datum changes within a sheet, but that's exceptional. There are also issues to do with the scale of the data - you have very detailed and frequently updated data in (say) the vicinity of major ports and shipping lanes, and much less detailed data in areas like (for example) the Southwestern Approaches. Handling data of widely differing scales in a single database is non-trivial (I've had to do it for Antarctica) and requires very careful rules about what to do when more detailed data impinges on less-detailed data.I was delighted to see the change, but they have already lost me as a customer as I'm not going to get lots of wee charts printed when I can use a much cheaper alternative. NV for the south coast and Imray for the rest.
I still think they should go down the OS route of being able to get a chart printed with a lat/long you select at its centre, @AntarcticPilot did explain why this is not currently possible.
True, but as a percentage of leisure craft the number of coded boats is tiny. For everybody else NV is an option.Not an MCA recognised chart agency - so no good for coded vessels
Only if you only sail the Englush Channel, for UK based boatsTrue, but as a percentage of leisure craft the number of coded boats is tiny. For everybody else NV is an option.
I'm currently based on the La Manche, but enjoy headingOnly if you only sail the Englush Channel, for UK based boats
- An aerial survey taking vertical air photos at a suitable scale and overlap.
- At least some ground control points, though these are less essential than they were, as the photocentres are fixed using high precision differential GPS in the aircraft. But at least a few are still required to produce the best results with the highest confidence.
- Analysis of the air photos to:
- Align the aerial photos (this is a complex, 3 dimensional problem - if anyone is interested, look up bundle adjustment). Usually a semi-automatic task, but still requires human input.
- Extract features of interest - generally a manual task.
- Extract surface elevation data - mostly automatic, but does require human checking.
- Carry out cartographic work to use the data from 3 to construct maps that are useful and carry the required information.
To be fair, USGS mapping in Antarctica is some of the best. But for the USA it doesn't even come close to the quality of OS mapping. I think - vague recollection - that the USGS did initiate a country wide aerial photo campaign, but I've no idea whether it actually happened.Part of my day job nearly 5 decades ago and before GPS, involved me being hands-on in doing all 4 of the above. The purpose being to generate 'photo-strip maps' using product from #1 which it made it practicable to fly low-level ( below radar ) strike missions against targets in otherwise ill-mapped terrain. One such was over 300nm long.
The 'photo-strip maps' thus produced were very crude - but they were sufficiently valid for the intended purpose.
The other mapping source was 1:500,000 Topographical sheets from the US - essentially useless.
I remain convinced that a “print on demand” service is viable (certainly by post but probably in chandleries) using the digital data that UKHO were planning to still have for electronic plotters.
[/QUOTE
All my charts are print-on-demand and delivered by post within days of ordering them online from a large chandlery in Halifax, Nova Scotia. The price is better than when they were printed by the Canadian Hydrographic Service and stocked by chandleries, who typically had only the ones for their local waters. A few years ago, the CHS asked for public comment on the need for paper charts, and many of the concerns raised by RYA, RIN, Cruising Assoc. et al. were brought up.
The “digital data” that the UKHO holds is all in vector format, per the international standards for IHO chart data. It needs both computer and skilled human intervention to convert into the raster images that can be Printed on Demand as paper charts.I remain convinced that a “print on demand” service is viable (certainly by post but probably in chandleries) using the digital data that UKHO were planning to still have for electronic plotters.
