BSJ2
Yep - that looks like it
Note
Includes full Memory-Map PC Software and Pocket Navigator™ for Windows Mobile.
I believe that this version of Memory Map is the standard one - If you want the Pro version, go to the USA site and upgrade. The Pro has AIS input and allows you to print out charts larger than A4. I often print paper charts on A3 paper and take them on the boat in plastic envelopes. You can scribble on them as much as you like then throw them away and print another (only when you need it).
mjf - note - this isn't Maptech's Offshore Navigator software.
Finally, there's a trick you can do with Memory Map that avoids the need to register the charts more than once. I hate software that insists on reregistering every time that you rebuild your PC - I dont mind paying for software but I really object it requiring re-registration every time you re-install the data. This is the main reason I like Memory Map so much. PM me for details.
is it safe to print out charts? as i have always been concerned about scales slightly changing?i know they always warn you when copying building site drawings etc?
