Bouba
Depends, what’s she want?Do you mean "Of whom are you speaking?"?
Look here, I don't mean to be rude, but do I know you?Depends, what’s she want?
Do you mean Wing Commander Crabbe?I am sure that even in those far off days it would have been possible to ascertain with reasonable certainty whether or not the headless body was that of Commander Crabbe or, having in mind Operation Mincemeat, that of some vagrant.
I still remember when a joke has run it’s course ...has this one???Look here, I don't mean to be rude, but do I know you?
...by the MOD who two days ago were unable to confirm if Amsterdam is nearer Portsmouth than is Rosyth.I’m sure every option has been considered
Might be if she was still using coal for bunkers.Today the front page of the Torygraph is reporting from 'naval sources' that it may have been a lack of grease on the shaft that caused the failure ... believable?? possible??
All very clear and absolutely on message - but - why send divers down for a inboard shaft bearing problem. Dinged propeller or damaged P or A bracket more likely. See my post 54 - and the known sensitivity of shaft alignment in her sister ship.Might be if she was still using coal for bunkers.
Sounds like a reporter who hasn’t a clue getting info from an insider who isn’t much wiser.
I would think even the RN would be using lube oil now, and if environmentally friendly bio degradable oil in shaft seals.
Loss of oil pressure to a shaft bearing would be a problem. A shaft with with slow speed RPM, It would have to run hot for quite some time before serious damage occurred.
Good ER watch keeping routine should be able to spot a problem developing before it get serious.
At the other end of the scale. A turbo bearing probably would fail almost immediately after Oil pressure was lost. Or be seriously damaged.
Traditionally. (MN I expect RN probably similar)
If problem is detected.
Bridge should be notified immediately, with request for permission to reduce speed and or shut it down.
Permission would normally be granted unless safety of vessel is an issue. in which caseit may be delayed until vessel is in location to safely reduce speed or shut down.
After shutting down, the bearing can be opened up and checked by ship engineers. provided the white metal is not gone shaft is probably ok. If replacement parts available bearing can be overhauled and rebuilt relatively easily, possible even by ships crew. figuring out why and sorting so it doesn't occur again might be more complex.
If shaft is scored. much bigger problem. requiring specialized tech and tools to regrind shaft.
It can actually be done with shaft pulled just far enough to clear blocks.
In some case it can even be done without having to dry dock. depends on the ability deballast and to trim vessel when light to by head until shaft is clear of water(might not be possible with ACC stern tube position .) or by creating a temporary cofferdam outside the hull.
Pretty much that; navies with carriers tend to have superdooper Yokohamas to avoid quayside/sponson interaction.A silly question probably, but how do they allow for a large tidal range with those impressive side overhangs?
I am wondering if they have large Yokohama type floating fenders to hold the vessel sufficiently far off the quayside, so that the overhangs don't bash the quay at low tide?
Divers will give the prop, shaft and stern seal a visual check for obvious damage, foreign objects etc. We do not know QE had problems with alignment, MoD have never elaborated.All very clear and absolutely on message - but - why send divers down for a inboard shaft bearing problem. Dinged propeller or damaged P or A bracket more likely. See my post 54 - and the known sensitivity of shaft alignment in her sister ship.
Interesting suggestion here that she departed with one shaft out of operation:
HMS Prince of Wales suffers technical issue after sailing from Portsmouth | Navy Lookout
Actually, just glancing through this publication - originally titled “Save the Royal Navy!” - turns up one horror story after another :
The Royal Navy’s Type 45 destroyers – status report | Navy Lookout
Maintenance problems for the Royal Navy mount up | Navy Lookout
It is notable that the “fix” for the Type 45 disaster does not fix it.
There is no plan to replace the WR21 gas turbines which have repeatedly tripped out under load. All that is being done is to replace the two diesel generators with three, so that the ships can operate as diesel ships, leaving the unreliable gas turbines to provide “sprint capability” (though the risk of breakdowns remains so high that the same publication reports, cheerfully, that HMS Defender actually achieved 30 knots on deployment in the Black Sea).
