jfm
unless I'm mistaken, the plate spinning on the teflon bearing is a little bit raised above the rest of the cover.
[/img]
All agreed 100% Mapis. Well, if (note, I say IF!) Speedseal are increasing impeller life by reducing the axial compression on the impeller that's a very poor show. The axial compression is a significant part of the fundamental seal design of the pump. Any user can reduce the axial compression just by inserting a thicker gasket. In some low-load/low-performance applications you might even get away with it, but customers ought to be told by Speedseal if the Speedseal Life axially lengthens the pump chamber in this way. Very poor form if Speedseal are doing this and not saying so imho. I very much hope they confirm that they are not doing this trick
