Ian_Edwards
Does anyone know the correct procedure for correctly aligning twin rudders?
And
Should they be parallel?
After I'd finished antifouling the boat I stood back to see how it looked, as you do. Then I noticed that the two rudders didn't seem to be parallel.
It's easy to adjust the tiebar between the rudders, but how and where do you measure from?
I could set-up a centre line using a string from the keel to the middle of the skeg, then extend it to a post or stepladder to establish a mid ships line.
I could then measure the distance between the lower tips of the of the trailing edges of the rudders to the center line, the rudders are rectangular and the lower corners are approximate square.
But where do I go from here?
Adjust the tie bar so that the centre of the leading edge of the rudders are equidistant from the centre line, and the same distance centre as the trailing edges.
That would seem to make then parallel.
Is that the correct procedure?
A yard had both rudders out to put key ways in the stocks for the quadrants. To stop the quadrants slipping, and I'm not sure that they got them back correctly.
And
