Tripping lines
bluetooth
30 Dec 2015
Poole
I'm planning on anchoring in Plymouth this summer and tripping lines are advised in certain areas. I rigged myself a small buoy and line to the head of anchor some years ago but never used it in Dorset and Solent areas as good sand and also little wary of causing a problem to others and getting it all tied up when retrieving the anchor!!
I've wondered whether using a ski tow rope which as it floats may make it easier to retrieve with the anchor. Once deployed I would then keep it tight ish to the bow rather than let it float everywhere and be a risk to others.
I have added to an existing post in Scuttlebutt forum (nice graphic in post#3) but thought I'd ask here as well.
Any thoughts
AndieMac
24 Mar 2009
Tasmania, Australia
Any thoughts
I think the angle of pull, whether it is tied to a floating buoy and retrieved with a boat hook from the bow sprit as the boat idles forward, or tied off to a bow located cleat, then pulled from the bow sprit, is going to be very similar.
If for some reason a dinghy is required to provide a different angle of pull/release, it’s the same deal.
